소개
Have you received a “Warning: Camera Failed” message or something similar? Is your camera lens on your LG K30 Phone cracked. These are signs that your LG Phone is in need a camera replacement.
Use this guide to install a new rear facing camera. As always, please ensure your phone is powered off completely.
필요한 것
Power off your Phone before beginning disassembly.
Use the 'Jimmy' and 'Metal Spudger' to slowly pry open the outsides of the back case.
Use a spudger to carefully disconnect the front camera connector.
Use a spudger to disconnect the display cable connector.
Use a Spudger to flip the release tab on the rear-facing camera cable ZIF connector.
Remove the rear-facing camera.
