주요 콘텐츠로 건너뛰기
LG K7 Screen Replacement
필요한 것
  1. LG K7 Screen Replacement, Screen: 1 단계, 이미지 1/3 LG K7 Screen Replacement, Screen: 1 단계, 이미지 2/3 LG K7 Screen Replacement, Screen: 1 단계, 이미지 3/3
    • Place phone face-down and use your nail to pry the back off the back.
  2. LG K7 Screen Replacement: 2 단계, 이미지 1/2 LG K7 Screen Replacement: 2 단계, 이미지 2/2
    • Use a plastic spudger or your nail to lift the battery out of the device and put it aside.
    • The battery should come out with little effort. If it does not, do not force it.
  3. LG K7 Screen Replacement: 3 단계, 이미지 1/3 LG K7 Screen Replacement: 3 단계, 이미지 2/3 LG K7 Screen Replacement: 3 단계, 이미지 3/3
    • Use a Phillips #0 screwdriver to remove the single 3.5mm screw holding the power button and volume rocker in place and lift it out and put it to the side.
  4. LG K7 Screen Replacement: 4 단계, 이미지 1/3 LG K7 Screen Replacement: 4 단계, 이미지 2/3 LG K7 Screen Replacement: 4 단계, 이미지 3/3
    • Use a Phillips #0 screwdriver to unscrew the three 3.5mm screws in the bottom portion of the phone and put them to the side.
    • Use a spudger to pry the plastic bit off. Be warned, it will pop out and might fling itself when you attempt to pry it out.
  5. LG K7 Screen Replacement: 5 단계, 이미지 1/3 LG K7 Screen Replacement: 5 단계, 이미지 2/3 LG K7 Screen Replacement: 5 단계, 이미지 3/3
    • Warning, it will snap out and might fling itself when you attempt to pry it out.
  6. LG K7 Screen Replacement: 6 단계, 이미지 1/3 LG K7 Screen Replacement: 6 단계, 이미지 2/3 LG K7 Screen Replacement: 6 단계, 이미지 3/3
    • Use a Phillips #0 screwdriver to unscrew the five 3.5mm screws holding the housing into the device.
    • Use a spudger to pop it out of the back of the device exposing the motherboard.
  7. LG K7 Screen Replacement: 7 단계, 이미지 1/3 LG K7 Screen Replacement: 7 단계, 이미지 2/3 LG K7 Screen Replacement: 7 단계, 이미지 3/3
    • Use a plastic spudger to lift the motherboard out of the casing.
    • You must use a plastic tool for this step or you may risk damaging the motherboard.
  8. LG K7 Screen Replacement: 8 단계, 이미지 1/3 LG K7 Screen Replacement: 8 단계, 이미지 2/3 LG K7 Screen Replacement: 8 단계, 이미지 3/3
    • Turn the device over and locate the connector between the digitizer and the motherboard.
    • Use a plastic spudger to disconnect the connector.
  9. LG K7 Screen Replacement: 9 단계, 이미지 1/1
    • Turn the screen housing over and use a hair dryer to heat the screen.
    • This melts the adhesive between the screen and the housing, allowing you to separate the two.
    • Be sure to evenly heat the screen and take care not to burn yourself.
  10. LG K7 Screen Replacement: 10 단계, 이미지 1/1
    • Once the screen is heated, use a plastic spudger to attempt to peel the glass away from the housing.
    • This will take some time, so take care not to break the glass.
    • Once the spudger is under the glass, drag it around the edge and separate the glass and the housing.
  11. LG K7 Screen Replacement: 11 단계, 이미지 1/2 LG K7 Screen Replacement: 11 단계, 이미지 2/2
    • You have now successfully removed the screen and digitizer from the housing.
결론
다른 8명이 해당 안내서를 완성하였습니다.
Christopher Chheng
회원 가입일: 11/01/18
559 평판
안내서 2개 작성하였습니다
IUPUI, Team S3-G4, Harley Fall 2018 IUPUI, Team S3-G4, Harley Fall 2018 회원
IUPUI-HARLEY-F18S3G4
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 1,721
