주요 콘텐츠로 건너뛰기
LG K7 T-Mobile Motherboard Replacement
필요한 것
  1. LG K7 T-Mobile Motherboard Replacement, Battery: 1 단계, 이미지 2개 중 1개 LG K7 T-Mobile Motherboard Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Flip the LG K7 over so that the back of the phone is facing up.
    • Locate the small notch on the bottom left side of the phone.
  2. LG K7 T-Mobile Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Insert a plastic opening tool into the notch and lift the back cover upward while holding the bottom portion of the phone down to remove it.
  3. LG K7 T-Mobile Motherboard Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the battery.
  4. LG K7 T-Mobile Motherboard Replacement, Motherboard: 4 단계, 이미지 2개 중 1개 LG K7 T-Mobile Motherboard Replacement, Motherboard: 4 단계, 이미지 2개 중 2개
    • Located to nine 3.4 mm screws that keep that keep the phones rear housing in tacked.
    • Using a Phillips 00 screwdriver remove all nine 3.4 mm screws.
  5. LG K7 T-Mobile Motherboard Replacement: 5 단계, 이미지 3개 중 1개 LG K7 T-Mobile Motherboard Replacement: 5 단계, 이미지 3개 중 2개 LG K7 T-Mobile Motherboard Replacement: 5 단계, 이미지 3개 중 3개
    • Turn the phone over so the screen is facing up.
    • Insert your plastic opening tool between the midframe and front panel assembly on the side of the phone.
    • Slide the plastic opening tool down the seams carefully to separate the screen from the rest of the phone housing.
  6. LG K7 T-Mobile Motherboard Replacement: 6 단계, 이미지 3개 중 1개 LG K7 T-Mobile Motherboard Replacement: 6 단계, 이미지 3개 중 2개 LG K7 T-Mobile Motherboard Replacement: 6 단계, 이미지 3개 중 3개
    • Locate the lock that holds the camera's ribbon cable in place.
    • Carefully remove the camera's ribbon cable from the motherboard using the plastic removal tool.
    • Holding the camera ribbon you just released pull upwards and the camera should release from the case.
  7. LG K7 T-Mobile Motherboard Replacement: 7 단계, 이미지 2개 중 1개 LG K7 T-Mobile Motherboard Replacement: 7 단계, 이미지 2개 중 2개
    • Locate the headphone jack towards the bottom right of the phone.
    • Place a plastic removal tool underneath the head phone jack.
    • Lift the plastic removal tool upward to remove the earphone jack from the phone case.
  8. LG K7 T-Mobile Motherboard Replacement: 8 단계, 이미지 2개 중 1개 LG K7 T-Mobile Motherboard Replacement: 8 단계, 이미지 2개 중 2개
    • Locate the ribbon for the front facing camera.
    • Carefully remove the front facing camera's ribbon cable from the motherboard using the plastic removal tool.
    • Holding the front camera ribbon you just released pull upwards and the camera should release from the case.
    • Remove the band that connects the screen display to the motherboard.
  9. LG K7 T-Mobile Motherboard Replacement: 9 단계, 이미지 2개 중 1개 LG K7 T-Mobile Motherboard Replacement: 9 단계, 이미지 2개 중 2개
    • Locate the ribbon cable that connects the screen to the motherboard.
    • Carefully remove the screen's ribbon cable from the motherboard using the plastic removal tool by lifting the ribbon cable upwards.
  10. LG K7 T-Mobile Motherboard Replacement: 10 단계, 이미지 3개 중 1개 LG K7 T-Mobile Motherboard Replacement: 10 단계, 이미지 3개 중 2개 LG K7 T-Mobile Motherboard Replacement: 10 단계, 이미지 3개 중 3개
    • Wedge a plastic opening tool between the motherboard and the phones casing.
    • While using one finger to hold down a portion of the phone pull upwards with the plastic opening tool to loosen the motherboard from the phone casing.
    • Once there is some space between the board and the phone case, using your hands carefully lift the motherboard from the phone casing.
결론
다른 7명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Brandon Jones
회원 가입일: 09/28/17
233 평판
안내서 1개를 작성함
USF Tampa, Team S2-G5, Nance Fall 2017 USF Tampa, Team S2-G5, Nance Fall 2017 회원
USFT-NANCE-F17S2G5
3 회원들
안내서 8개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 5
지난 30일: 8
전체 시간: 2,230
