주요 콘텐츠로 건너뛰기
LG KP100 Battery Replacement
  1. LG KP100 Battery Replacement, Battery: 1 단계, 이미지 1/2 LG KP100 Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Begin by taking the back battery cover off.
    • Put your index finger on the white notch and apply pressure.
    • While applying pressure, move your hand backwards to slide the battery cover off of the body of the phone.
  2. LG KP100 Battery Replacement: 2 단계, 이미지 1/2 LG KP100 Battery Replacement: 2 단계, 이미지 2/2
    • Remove the battery.
    • Put your index finger in the notch above the battery near the top of the casing.
    • While applying pressure against the battery, lift up and take out the battery.
결론
Preston Brown
회원 가입일: 04/12/12
28 평판
안내서 5개 작성하였습니다
Cal Poly, Team 6-20, Amido Spring 2012 Cal Poly, Team 6-20, Amido Spring 2012 회원
CPSU-AMIDO-S12S6G20
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 1,135
