소개
Your carrier most likely provided a SIM card to be installed in your phone, which will store your account information. Before using the phone, you will need to install this component.
도구
도구는 필요하지 않습니다.
부품
부품은 필요하지 않습니다.
  1. Begin by taking the back battery cover off. Put your index finger on the white notch and apply pressure.
    • Begin by taking the back battery cover off.
      • Put your index finger on the white notch and apply pressure.
      • While applying pressure, move your hand backwards to slide the battery cover off of the body of the phone.
  2. US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  3. Remove the battery. Put your index finger in the notch above the battery near the top of the casing.
    • Remove the battery.
      • Put your index finger in the notch above the battery near the top of the casing.
      • While applying pressure against the battery, lift up and take out the battery.
  4. Remove the SIM card from its housing. Put your finger in the provided notch below the SIM card and begin to push the SIM card towards the top of the device. After it is out of the metal housing, it is free to be removed.
    • Remove the SIM card from its housing.
      • Put your finger in the provided notch below the SIM card and begin to push the SIM card towards the top of the device.
      • After it is out of the metal housing, it is free to be removed.
결론
Preston Brown
회원 가입일: 2012년 04월 12일
22 평판
안내서 5개 작성하였습니다
Cal Poly, Team 6-20, Amido Spring 2012 Cal Poly, Team 6-20, Amido Spring 2012 회원
CPSU-AMIDO-S12S6G20
4 회원들
안내서 10개 작성하였습니다
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 1,001
