주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG L1200 Camera Replacement
필요한 것
  1. LG L1200 Camera Replacement, Inner LCD Screen: 1 단계, 이미지 1개 중 1개
    • Make sure you remove the battery by lifting the tab on the back of the phone before opening the case.
    • Flip open the phone and locate the four screw covers.
  2. LG L1200 Camera Replacement: 2 단계, 이미지 1개 중 1개
    • Remove all four screw covers by using an IPod opening tool. They should come off relatively easy.
  3. LG L1200 Camera Replacement: 3 단계, 이미지 1개 중 1개
    • Using a T6 Torx screwdriver, remove all four screws.
  4. LG L1200 Camera Replacement: 4 단계, 이미지 3개 중 1개 LG L1200 Camera Replacement: 4 단계, 이미지 3개 중 2개 LG L1200 Camera Replacement: 4 단계, 이미지 3개 중 3개
    • Once the screws are removed, use an IPod opening tool to separate the front cover from the inner screen cover.
    • Run the Ipod opening tool down both sides,disconnecting the tabs that hold the covers together.
  5. LG L1200 Camera Replacement: 5 단계, 이미지 2개 중 1개 LG L1200 Camera Replacement: 5 단계, 이미지 2개 중 2개
    • Pull the inner screen cover towards you and up in order to separate it from the front cover.
  6. LG L1200 Camera Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the tape from the bottom of the LCD screen.
  7. LG L1200 Camera Replacement: 7 단계, 이미지 3개 중 1개 LG L1200 Camera Replacement: 7 단계, 이미지 3개 중 2개 LG L1200 Camera Replacement: 7 단계, 이미지 3개 중 3개
    • Carefully lift the LCD screen and peel it from the gold ribbon. The sticky connection runs all the way around the LCD screen.
  8. LG L1200 Camera Replacement: 8 단계, 이미지 3개 중 1개 LG L1200 Camera Replacement: 8 단계, 이미지 3개 중 2개 LG L1200 Camera Replacement: 8 단계, 이미지 3개 중 3개
    • Flip the screen over so that you can see the outer LCD screen and the circuit board.
    • Insert spudger in the bottom right corner.
    • Lift up and move the spudger across the bottom.
    • The third photo is rotated 180 degrees.
  9. LG L1200 Camera Replacement: 9 단계, 이미지 2개 중 1개 LG L1200 Camera Replacement: 9 단계, 이미지 2개 중 2개
    • Use the pointy side of the spudger to peel off the interior tape.
    • Flip the assembly over and peel the circuit board from the screen.
  10. LG L1200 Camera Replacement: 10 단계, 이미지 2개 중 1개 LG L1200 Camera Replacement: 10 단계, 이미지 2개 중 2개
    • Use the spudger to remove the LCD screen from its backing.
  11. LG L1200 Camera Replacement, Camera: 11 단계, 이미지 1개 중 1개
    • Carefully slide the spudger behind the main ribbon in order to separate it from the inside cover of the phone.
  12. LG L1200 Camera Replacement: 12 단계, 이미지 2개 중 1개 LG L1200 Camera Replacement: 12 단계, 이미지 2개 중 2개
    • Use a spudger to pop off the camera ribbon from the main ribbon. The camera component should separate entirely.
결론
작성자
4다른 기여자 명과 함께
Joshua Herrmann
회원 가입일: 04/16/10
8 평판
안내서 8개를 작성함
Cal Poly, Team 6-14, Maness Spring 2010 Cal Poly, Team 6-14, Maness Spring 2010 회원
CPSU-MANESS-S10S6G14
4 회원들
안내서 16개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 10
지난 7일: 23
지난 30일: 87
전체 시간: 1,511
