주요 콘텐츠로 건너뛰기
LG L1200 Internal Speaker Replacement
필요한 것
  1. LG L1200 Internal Speaker Replacement, Inner LCD Screen: 1 단계, 이미지 1/1
    • Make sure you remove the battery by lifting the tab on the back of the phone before opening the case.
    • Flip open the phone and locate the four screw covers.
  2. LG L1200 Internal Speaker Replacement: 2 단계, 이미지 1/1
    • Remove all four screw covers by using an IPod opening tool. They should come off relatively easy.
  3. LG L1200 Internal Speaker Replacement: 3 단계, 이미지 1/1
    • Using a T6 Torx screwdriver, remove all four screws.
  4. LG L1200 Internal Speaker Replacement: 4 단계, 이미지 1/3 LG L1200 Internal Speaker Replacement: 4 단계, 이미지 2/3 LG L1200 Internal Speaker Replacement: 4 단계, 이미지 3/3
    • Once the screws are removed, use an IPod opening tool to separate the front cover from the inner screen cover.
    • Run the Ipod opening tool down both sides,disconnecting the tabs that hold the covers together.
  5. LG L1200 Internal Speaker Replacement: 5 단계, 이미지 1/2 LG L1200 Internal Speaker Replacement: 5 단계, 이미지 2/2
    • Pull the inner screen cover towards you and up in order to separate it from the front cover.
  6. LG L1200 Internal Speaker Replacement: 6 단계, 이미지 1/1
    • Remove the tape from the bottom of the LCD screen.
  7. LG L1200 Internal Speaker Replacement: 7 단계, 이미지 1/3 LG L1200 Internal Speaker Replacement: 7 단계, 이미지 2/3 LG L1200 Internal Speaker Replacement: 7 단계, 이미지 3/3
    • Carefully lift the LCD screen and peel it from the gold ribbon. The sticky connection runs all the way around the LCD screen.
  8. LG L1200 Internal Speaker Replacement: 8 단계, 이미지 1/3 LG L1200 Internal Speaker Replacement: 8 단계, 이미지 2/3 LG L1200 Internal Speaker Replacement: 8 단계, 이미지 3/3
    • Flip the screen over so that you can see the outer LCD screen and the circuit board.
    • Insert spudger in the bottom right corner.
    • Lift up and move the spudger across the bottom.
    • The third photo is rotated 180 degrees.
  9. LG L1200 Internal Speaker Replacement: 9 단계, 이미지 1/2 LG L1200 Internal Speaker Replacement: 9 단계, 이미지 2/2
    • Use the pointy side of the spudger to peel off the interior tape.
    • Flip the assembly over and peel the circuit board from the screen.
  10. LG L1200 Internal Speaker Replacement: 10 단계, 이미지 1/2 LG L1200 Internal Speaker Replacement: 10 단계, 이미지 2/2
    • Use the spudger to remove the LCD screen from its backing.
  11. LG L1200 Internal Speaker Replacement, Internal Speaker: 11 단계, 이미지 1/1
    • Desolder the wires connecting the speaker.
    • Solder on wires from new speaker.
결론
Joshua Herrmann
회원 가입일: 04/16/10
8 평판
안내서 8개 작성하였습니다
Cal Poly, Team 6-14, Maness Spring 2010 Cal Poly, Team 6-14, Maness Spring 2010 회원
CPSU-MANESS-S10S6G14
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 1,415
