주요 콘텐츠로 건너뛰기
LG LX150 Battery Replacement
  1. LG LX150 Battery Replacement, Back Cover: 1 단계, 이미지 1/3 LG LX150 Battery Replacement, Back Cover: 1 단계, 이미지 2/3 LG LX150 Battery Replacement, Back Cover: 1 단계, 이미지 3/3
    • First locate the button and the bottom of the cover where the arrow is. Press down on the button.
    • While pushing down on the button, slide the cover up towards the hinge until the cover comes off.
    • The battery will be visible after removing the back cover.
  2. LG LX150 Battery Replacement, Battery: 2 단계, 이미지 1/2 LG LX150 Battery Replacement, Battery: 2 단계, 이미지 2/2
    • Simultaneously push the battery forward and pull up from the bottom.
  3. LG LX150 Battery Replacement: 3 단계, 이미지 1/1
    • Once the battery is loose it can be easily removed. The phone's ID tag will be visible once the battery is removed.
    • Be careful of damaged or leaking batteries. If your battery appears damaged, remove it with care and find a replacement.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Andrea
회원 가입일: 04/19/10
110 평판
안내서 4개 작성하였습니다
Cal Poly, Team 10-44, Garner Spring 2010 Cal Poly, Team 10-44, Garner Spring 2010 회원
CPSU-GARNER-S10S10G44
4 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 1,415
