주요 콘텐츠로 건너뛰기
LG LX150 Internal Back Cover Replacement
필요한 것
  1. LG LX150 Internal Back Cover Replacement, Back Cover: 1 단계, 이미지 1/3 LG LX150 Internal Back Cover Replacement, Back Cover: 1 단계, 이미지 2/3 LG LX150 Internal Back Cover Replacement, Back Cover: 1 단계, 이미지 3/3
    • First locate the button and the bottom of the cover where the arrow is. Press down on the button.
    • While pushing down on the button, slide the cover up towards the hinge until the cover comes off.
    • The battery will be visible after removing the back cover.
  2. LG LX150 Internal Back Cover Replacement, Battery: 2 단계, 이미지 1/2 LG LX150 Internal Back Cover Replacement, Battery: 2 단계, 이미지 2/2
    • Simultaneously push the battery forward and pull up from the bottom.
  3. LG LX150 Internal Back Cover Replacement: 3 단계, 이미지 1/1
    • Once the battery is loose it can be easily removed. The phone's ID tag will be visible once the battery is removed.
    • Be careful of damaged or leaking batteries. If your battery appears damaged, remove it with care and find a replacement.
  4. LG LX150 Internal Back Cover Replacement, Internal Back Cover: 4 단계, 이미지 1/3 LG LX150 Internal Back Cover Replacement, Internal Back Cover: 4 단계, 이미지 2/3 LG LX150 Internal Back Cover Replacement, Internal Back Cover: 4 단계, 이미지 3/3
    • Remove the 7 phillips screws indicated by the red arrows using the phillips #0 screwdriver.
    • Insert the flat end of the spudger in-between the black and blue phone casing on the side of the phone and split the the blue and black apart. Work your way around the perimeter of the cover, loosening all corners.
  5. LG LX150 Internal Back Cover Replacement: 5 단계, 이미지 1/2 LG LX150 Internal Back Cover Replacement: 5 단계, 이미지 2/2
    • Remove the internal back cover after loosening all the corners.
    • The second picture below is what you will see after removing the internal back cover.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Daniel Simpson
회원 가입일: 04/18/10
60 평판
안내서 2개 작성하였습니다
Cal Poly, Team 10-44, Garner Spring 2010 Cal Poly, Team 10-44, Garner Spring 2010 회원
CPSU-GARNER-S10S10G44
4 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 13
전체 시간: 1,674
