주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG LX150 Keypad Replacement
필요한 것
  1. LG LX150 Keypad Replacement, Back Cover: 1 단계, 이미지 3개 중 1개 LG LX150 Keypad Replacement, Back Cover: 1 단계, 이미지 3개 중 2개 LG LX150 Keypad Replacement, Back Cover: 1 단계, 이미지 3개 중 3개
    • First locate the button and the bottom of the cover where the arrow is. Press down on the button.
    • While pushing down on the button, slide the cover up towards the hinge until the cover comes off.
    • The battery will be visible after removing the back cover.
  2. LG LX150 Keypad Replacement, Battery: 2 단계, 이미지 2개 중 1개 LG LX150 Keypad Replacement, Battery: 2 단계, 이미지 2개 중 2개
    • Simultaneously push the battery forward and pull up from the bottom.
  3. LG LX150 Keypad Replacement: 3 단계, 이미지 1개 중 1개
    • Once the battery is loose it can be easily removed. The phone's ID tag will be visible once the battery is removed.
    • Be careful of damaged or leaking batteries. If your battery appears damaged, remove it with care and find a replacement.
  4. LG LX150 Keypad Replacement, Internal Back Cover: 4 단계, 이미지 3개 중 1개 LG LX150 Keypad Replacement, Internal Back Cover: 4 단계, 이미지 3개 중 2개 LG LX150 Keypad Replacement, Internal Back Cover: 4 단계, 이미지 3개 중 3개
    • Remove the 7 phillips screws indicated by the red arrows using the phillips #0 screwdriver.
    • Insert the flat end of the spudger in-between the black and blue phone casing on the side of the phone and split the the blue and black apart. Work your way around the perimeter of the cover, loosening all corners.
  5. LG LX150 Keypad Replacement: 5 단계, 이미지 2개 중 1개 LG LX150 Keypad Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the internal back cover after loosening all the corners.
    • The second picture below is what you will see after removing the internal back cover.
  6. LG LX150 Keypad Replacement, Motherboard: 6 단계, 이미지 1개 중 1개
    • Lift the motherboard from the bottom to loosen it.
  7. LG LX150 Keypad Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the pin socket that connects the screen to the motherboard by pulling up away from the motherboard.
  8. LG LX150 Keypad Replacement: 8 단계, 이미지 2개 중 1개 LG LX150 Keypad Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the motherboard.
    • The keypad will now be visible, as shown in the second picture.
  9. LG LX150 Keypad Replacement, Keypad: 9 단계, 이미지 1개 중 1개
    • To remove the key pad, simply pull it off from the LG LX150 frame.
  10. LG LX150 Keypad Replacement: 10 단계, 이미지 1개 중 1개
    • When the key pad is removed, the frame will be all that is left.
    • If you wish to replace the key pad, place the new keypad on to the frame and reassemble the phone to resume use.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Andrea
회원 가입일: 04/19/10
110 평판
안내서 4개를 작성함
Cal Poly, Team 10-44, Garner Spring 2010 Cal Poly, Team 10-44, Garner Spring 2010 회원
CPSU-GARNER-S10S10G44
4 회원들
안내서 18개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 100
전체 시간: 1,268
