주요 콘텐츠로 건너뛰기
LG LX150 Screen Replacement
필요한 것
  1. LG LX150 Screen Replacement, Front Cover: 1 단계, 이미지 1/3 LG LX150 Screen Replacement, Front Cover: 1 단계, 이미지 2/3 LG LX150 Screen Replacement, Front Cover: 1 단계, 이미지 3/3
    • Use the spudger to pry out the indicated rubber squares.
    • Use the #0 Phillips screwdriver to take out the revealed screws.
  2. LG LX150 Screen Replacement: 2 단계, 이미지 1/3 LG LX150 Screen Replacement: 2 단계, 이미지 2/3 LG LX150 Screen Replacement: 2 단계, 이미지 3/3
    • Carefully lodge the spudger between the face plate and the hinge mechanism.
    • Gently pry the face plate until it releases from place holders.
  3. LG LX150 Screen Replacement, Screen: 3 단계, 이미지 1/2 LG LX150 Screen Replacement, Screen: 3 단계, 이미지 2/2
    • Apply even amounts of force upon removing screen, otherwise cracking may occur.
    • Gently loosen the screen from its adhesive by pressing around the screen's rear perimeter with a spudger. Place upward pressure in crevices between face plate and screen.
    • Carefully use both thumbs and apply pressure to the back of the screen to pop out.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Tye Barba
회원 가입일: 04/15/10
88 평판
안내서 2개 작성하였습니다
Cal Poly, Team 10-44, Garner Spring 2010 Cal Poly, Team 10-44, Garner Spring 2010 회원
CPSU-GARNER-S10S10G44
4 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 1,343
