소개
Use this guide to remove the LG LX150's sceen.
필요한 것
Use the spudger to pry out the indicated rubber squares.
Use the #0 Phillips screwdriver to take out the revealed screws.
Gently loosen the screen from its adhesive by pressing around the screen's rear perimeter with a spudger. Place upward pressure in crevices between face plate and screen.
Carefully use both thumbs and apply pressure to the back of the screen to pop out.
다른 한 분이 해당 안내서를 완성하였습니다.
