주요 콘텐츠로 건너뛰기
LG LX160 Battery Replacement
  1. LG LX160 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Place the phone on a flat surface with the back facing upward.
    • Remove the back panel by placing your thumb on the LG logo and sliding the panel in a downward motion until the panel is removed.
  2. LG LX160 Battery Replacement: 2 단계, 이미지 1/1
    • Once the panel is removed, you will see the battery. Remove the battery by sliding your finger into the notch where the LG logo was on the panel and lift the battery.
  3. LG LX160 Battery Replacement: 3 단계, 이미지 1/1
    • Remove the battery completely from the phone and place the battery off to the side.
결론
David Baruela
회원 가입일: 01/14/10
1 평판
안내서 1개 작성함
Cal Poly, Team 11-2, Forte Winter 2010 Cal Poly, Team 11-2, Forte Winter 2010 회원
CPSU-FORTE-W10S11G2
5 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 11
전체 시간: 2,192
