소개
This guide will show you how to replace a worn out, scratched, or damaged internal keyboard on the LG LX160 cell phone. To begin this guide, complete steps 1 to 10 of the tear down guide
부품
부품은 필요하지 않습니다.
  1. Place the phone on a flat surface that the back is facing you. Remove the back panel by placing your thumb on the LG logo and sliding the panel across the length of the phone until it is removed.
    • Place the phone on a flat surface that the back is facing you. Remove the back panel by placing your thumb on the LG logo and sliding the panel across the length of the phone until it is removed.
  2. Once the panel is removed, you are looking directly at the battery. It is the black rectangle in the middle of the phone.  You can remove the battery by sliding a finger into the notch where the LG logo was on the panel and lifting up the battery.
    • Once the panel is removed, you are looking directly at the battery. It is the black rectangle in the middle of the phone. You can remove the battery by sliding a finger into the notch where the LG logo was on the panel and lifting up the battery.
  3. Remove the battery completely from the phone.
    • Remove the battery completely from the phone.
  4. Before continuing pull off all the rubber tabs to the headphones, and the power input.
    • Before continuing pull off all the rubber tabs to the headphones, and the power input.
  5. US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  6. Now turn the phone so that you can see the back where the battery was.  Using a screw driver, unscrew the 6 screws holding the back casing together.
    • Now turn the phone so that you can see the back where the battery was. Using a screw driver, unscrew the 6 screws holding the back casing together.
  7. At the top of the logic board there is a small rectangle with a white pad on it, use your tweezers and gently grip the neck of the orange wire.
    • At the top of the logic board there is a small rectangle with a white pad on it, use your tweezers and gently grip the neck of the orange wire.
    • Gently pull up on the orange wire until it comes loose. It may take some force so do not be concerned with being overly gentle.
  8. After pulling on the orange wire it should come loose like the image.
    • After pulling on the orange wire it should come loose like the image.
    • Be sure that the black chip on the underside of the orange wire is all the way out like in the picture before continuing to the next step.
  9. Now you can remove the logic board from the casing, and set it aside.
    • Now you can remove the logic board from the casing, and set it aside.
    • If you're replacing the logic board insert the board into the phone and attach the phone via the small orange tab
  10. Peel out the keypad in the back of the phone. It is the white flimsy plastic from the bottom.
    • Peel out the keypad in the back of the phone. It is the white flimsy plastic from the bottom.
  11. The keyboard will be separated and may be replaced with a new keyboard.
    • The keyboard will be separated and may be replaced with a new keyboard.
결론
Shane Smith
회원 가입일: 2010년 01월 14일
1 평판
안내서 2개 작성하였습니다
Cal Poly, Team 11-2, Forte Winter 2010 Cal Poly, Team 11-2, Forte Winter 2010 회원
CPSU-FORTE-W10S11G2
5 회원들
안내서 10개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 2
전체 시간: 1,403
