주요 콘텐츠로 건너뛰기
LG LX160 Keyboard Replacement
필요한 것
  1. LG LX160 Keyboard Replacement, Battery: 1 단계, 이미지 1/1
    • Place the phone on a flat surface with the back facing upward.
    • Remove the back panel by placing your thumb on the LG logo and sliding the panel in a downward motion until the panel is removed.
  2. LG LX160 Keyboard Replacement: 2 단계, 이미지 1/1
    • Once the panel is removed, you will see the battery. Remove the battery by sliding your finger into the notch where the LG logo was on the panel and lift the battery.
  3. LG LX160 Keyboard Replacement: 3 단계, 이미지 1/1
    • Remove the battery completely from the phone and place the battery off to the side.
  4. LG LX160 Keyboard Replacement, Motherboard: 4 단계, 이미지 1/1
    • Before continuing pull off all the rubber tabs to the headphones, and the power input.
  5. LG LX160 Keyboard Replacement: 5 단계, 이미지 1/1
    • Now turn the phone so that you can see the back where the battery was. Using a screw driver, unscrew the 6 screws holding the back casing together.
  6. LG LX160 Keyboard Replacement: 6 단계, 이미지 1/1
    • At the top of the logic board there is a small rectangle with a white pad on it, use your tweezers and gently grip the neck of the orange wire.
    • Gently pull up on the orange wire until it comes loose. It may take some force so do not be concerned with being overly gentle.
  7. LG LX160 Keyboard Replacement: 7 단계, 이미지 1/1
    • After pulling on the orange wire it should come loose like the image.
    • Be sure that the black chip on the underside of the orange wire is all the way out like in the picture before continuing to the next step.
  8. LG LX160 Keyboard Replacement: 8 단계, 이미지 1/1
    • Now you can remove the logic board from the casing, and set it aside.
    • If you're replacing the logic board insert the board into the phone and attach the phone via the small orange tab
  9. LG LX160 Keyboard Replacement, Keyboard: 9 단계, 이미지 1/1
    • Peel out the keypad in the back of the phone. It is the white flimsy plastic from the bottom.
  10. LG LX160 Keyboard Replacement: 10 단계, 이미지 1/1
    • The keyboard will be separated and may be replaced with a new keyboard.
결론
Shane Smith
회원 가입일: 01/14/10
1 평판
안내서 2개 작성하였습니다
Cal Poly, Team 11-2, Forte Winter 2010 Cal Poly, Team 11-2, Forte Winter 2010 회원
CPSU-FORTE-W10S11G2
5 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 1,510
