주요 콘텐츠로 건너뛰기
LG Leon LTE Battery Replacement
필요한 것
  1. LG Leon LTE Battery Replacement, Battery: 1 단계, 이미지 1/2 LG Leon LTE Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Flip phone to the back so you can access back of the phone which holds the battery.
  2. LG Leon LTE Battery Replacement: 2 단계, 이미지 1/2 LG Leon LTE Battery Replacement: 2 단계, 이미지 2/2
    • Pry the back of the phone open in the incision area at the bottom of the phone with your opening tool in an upward direction to retrieve access to the battery.
    • Some force will be needed
  3. LG Leon LTE Battery Replacement: 3 단계, 이미지 1/1
    • Once the back is removed, you will have access to the battery. Remove the battery and insert a replacement.
    • The battery is missing in this photo.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Geul Kim
회원 가입일: 01/29/18
604 평판
안내서 5개 작성하였습니다
University of Alabama, Team S1-G3, Bedsole Spring 2018 University of Alabama, Team S1-G3, Bedsole Spring 2018 회원
UA-BEDSOLE-S18S1G3
3 회원들
안내서 10개 작성하였습니다
댓글 한 개
Could my LG LEON 4G LTE smartphone need a new battery, I have had it for about 7 - 8 years, same original battery. Phone overheats at times, which I let cool. And getting black & white lines vertically on the screen. Also the screen fades out to a white / grey picture. Can the battery be doing this,just.started doing this not long ago PLEASE HELP. Cannot afford a new phone at this time.
Stephen Sylvia - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 15
전체 시간: 856
