주요 콘텐츠로 건너뛰기
소개
This guide will walk you through the process of replacing a earpiece speaker.
부품
지정된 부품이 없습니다.
  1. Flip phone to the back so you can access back of the phone which holds the battery. Flip phone to the back so you can access back of the phone which holds the battery.
    • Flip phone to the back so you can access back of the phone which holds the battery.
  2. Pry the back of the phone open in the incision area at the bottom of the phone with your opening tool in an upward direction to retrieve access to the battery. Pry the back of the phone open in the incision area at the bottom of the phone with your opening tool in an upward direction to retrieve access to the battery. Pry the back of the phone open in the incision area at the bottom of the phone with your opening tool in an upward direction to retrieve access to the battery.
    • Pry the back of the phone open in the incision area at the bottom of the phone with your opening tool in an upward direction to retrieve access to the battery.
  3. Once the back is removed you will have access to the 8 screws that need to be unscrewed with the Phillips #0 screwdriver. Once all screws are free use the opening tool to pry the back frame of the phone apart. Once the back is removed you will have access to the 8 screws that need to be unscrewed with the Phillips #0 screwdriver. Once all screws are free use the opening tool to pry the back frame of the phone apart. Once the back is removed you will have access to the 8 screws that need to be unscrewed with the Phillips #0 screwdriver. Once all screws are free use the opening tool to pry the back frame of the phone apart.
    • Once the back is removed you will have access to the 8 screws that need to be unscrewed with the Phillips #0 screwdriver. Once all screws are free use the opening tool to pry the back frame of the phone apart.
  4. At this point you should have access to the motherboard. At this point you should have access to the motherboard.
    • At this point you should have access to the motherboard.
  5. Use opening tool to get the earpiece. Use opening tool to get the earpiece.
    • Use opening tool to get the earpiece.
결론
Geul Kim
회원 가입일: 2018년 01월 29일
544 평판
안내서 5개 작성하였습니다
University of Alabama, Team S1-G3, Bedsole Spring 2018 University of Alabama, Team S1-G3, Bedsole Spring 2018 회원
UA-BEDSOLE-S18S1G3
3 회원들
안내서 5개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 2
지난 30일: 4
전체 시간: 219
