주요 콘텐츠로 건너뛰기
LG Leon LTE Motherboard Replacement
필요한 것
  1. LG Leon LTE Motherboard Replacement, Motherboard: 1 단계, 이미지 1/2 LG Leon LTE Motherboard Replacement, Motherboard: 1 단계, 이미지 2/2
    • Turn the phone over so the back is facing upward.
  2. LG Leon LTE Motherboard Replacement: 2 단계, 이미지 1/3 LG Leon LTE Motherboard Replacement: 2 단계, 이미지 2/3 LG Leon LTE Motherboard Replacement: 2 단계, 이미지 3/3
    • Insert your opening tool in the incision at the bottom center of the phone.
    • Push upward with the opening tool to pry the back of the phone open.
    • Remove the back completely and set aside.
  3. LG Leon LTE Motherboard Replacement: 3 단계, 이미지 1/3 LG Leon LTE Motherboard Replacement: 3 단계, 이미지 2/3 LG Leon LTE Motherboard Replacement: 3 단계, 이미지 3/3
    • Using the Phillips #0 screwdriver, unscrew the 8 screws that secure the back frame to the body of the phone.
    • Remember to put the screws in a safe place so you don't lose them.
    • Once all screws are removed, use the opening tool to pry the back frame of the phone free.
  4. LG Leon LTE Motherboard Replacement: 4 단계, 이미지 1/2 LG Leon LTE Motherboard Replacement: 4 단계, 이미지 2/2
    • Using the opening tool, gently pry the phone's earpiece off. Set aside.
    • Separate the old motherboard from the phone fixture by pulling it apart.
    • Gently press the replacement motherboard into the phone fixture.
결론
Geul Kim
회원 가입일: 01/29/18
604 평판
안내서 5개 작성하였습니다
University of Alabama, Team S1-G3, Bedsole Spring 2018 University of Alabama, Team S1-G3, Bedsole Spring 2018 회원
UA-BEDSOLE-S18S1G3
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 13
전체 시간: 697
