주요 콘텐츠로 건너뛰기
LG Leon LTE SIM Card Replacement
필요한 것
  1. LG Leon LTE SIM Card Replacement, SIM card: 1 단계, 이미지 1/2 LG Leon LTE SIM Card Replacement, SIM card: 1 단계, 이미지 2/2
    • First, make sure to turn the phone over so that you are viewing the backside. The battery is located inside the back of the phone.
  2. LG Leon LTE SIM Card Replacement: 2 단계, 이미지 1/3 LG Leon LTE SIM Card Replacement: 2 단계, 이미지 2/3 LG Leon LTE SIM Card Replacement: 2 단계, 이미지 3/3
    • Second, using your opening tool in an upward direction, carefully pry the back of the phone open at the incision area. This can be found at the bottom of the phone. You will now have access to the battery.
    • Once you have access to the battery, remove it carefully so that you can get to the SIM card. The SIM card can be seen in the third image.
    • Battery removal is not pictured.
  3. LG Leon LTE SIM Card Replacement: 3 단계, 이미지 1/2 LG Leon LTE SIM Card Replacement: 3 단계, 이미지 2/2
    • Once the SIM card is accessible, slide it from the SIM holder as demonstrated. Apply a downward force in an outward motion.
    • Slight force will be needed when pulling the SIM card from the SIM card holder.
결론
Geul Kim
회원 가입일: 01/29/18
604 평판
안내서 5개 작성하였습니다
University of Alabama, Team S1-G3, Bedsole Spring 2018 University of Alabama, Team S1-G3, Bedsole Spring 2018 회원
UA-BEDSOLE-S18S1G3
3 회원들
안내서 10개 작성하였습니다
댓글 한 개
You should do one on how to replace the SIM card tray
Wolfgang 847 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 14
전체 시간: 735
