주요 콘텐츠로 건너뛰기
LG Lucid 4G Battery Replacement
필요한 것
  1. LG Lucid 4G Battery Replacement, Battery: 1 단계, 이미지 1/3 LG Lucid 4G Battery Replacement, Battery: 1 단계, 이미지 2/3 LG Lucid 4G Battery Replacement, Battery: 1 단계, 이미지 3/3
    • Turn off the phone by pressing the power button, then press "Power Off", then press "OK" when notified that your phone will shut down.
  2. LG Lucid 4G Battery Replacement: 2 단계, 이미지 1/2 LG Lucid 4G Battery Replacement: 2 단계, 이미지 2/2
    • Flip the phone so that its back plate is facing upward.
    • Use your fingernail or prying tool to lift the back plate of the phone open by using the notch at the bottom.
  3. LG Lucid 4G Battery Replacement: 3 단계, 이미지 1/2 LG Lucid 4G Battery Replacement: 3 단계, 이미지 2/2
    • Using the notch located near the bottom center, remove the battery with a prying tool or your fingernail.
결론
Margaret Huck
회원 가입일: 02/07/17
219 평판
안내서 2개 작성하였습니다
Ohio State, Team 1-1, Wilder Spring 2017 Ohio State, Team 1-1, Wilder Spring 2017 회원
OSU-WILDER-S17S1G1
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 305
