주요 콘텐츠로 건너뛰기
LG Lucid 4G Headphone Jack Replacement
필요한 것
  1. LG Lucid 4G Headphone Jack Replacement, Battery: 1 단계, 이미지 1/3 LG Lucid 4G Headphone Jack Replacement, Battery: 1 단계, 이미지 2/3 LG Lucid 4G Headphone Jack Replacement, Battery: 1 단계, 이미지 3/3
    • Turn off the phone by pressing the power button, then press "Power Off", then press "OK" when notified that your phone will shut down.
  2. LG Lucid 4G Headphone Jack Replacement: 2 단계, 이미지 1/2 LG Lucid 4G Headphone Jack Replacement: 2 단계, 이미지 2/2
    • Flip the phone so that its back plate is facing upward.
    • Use your fingernail or prying tool to lift the back plate of the phone open by using the notch at the bottom.
  3. LG Lucid 4G Headphone Jack Replacement: 3 단계, 이미지 1/2 LG Lucid 4G Headphone Jack Replacement: 3 단계, 이미지 2/2
    • Using the notch located near the bottom center, remove the battery with a prying tool or your fingernail.
  4. LG Lucid 4G Headphone Jack Replacement, Headphone Jack: 4 단계, 이미지 1/1
    • Remove the 7 ph000 screws found on the back of the phone.
  5. LG Lucid 4G Headphone Jack Replacement: 5 단계, 이미지 1/2 LG Lucid 4G Headphone Jack Replacement: 5 단계, 이미지 2/2
    • Once all the screws are removed, use a plastic opening tool to lift off the plastic cover. There are notches on the left side by the micro SD port.
    • It may be difficult to pry the plastic over off. You may need to use some force.
  6. LG Lucid 4G Headphone Jack Replacement: 6 단계, 이미지 1/1
    • Next, remove another screw located in top left quadrant of phone.
  7. LG Lucid 4G Headphone Jack Replacement: 7 단계, 이미지 1/2 LG Lucid 4G Headphone Jack Replacement: 7 단계, 이미지 2/2
    • Remove SIM card holding by prying it with opening tool. As you are lifting it, disconnect the ribbon that is connecting the sim card holding and the rest of the phone.
  8. LG Lucid 4G Headphone Jack Replacement: 8 단계, 이미지 1/2 LG Lucid 4G Headphone Jack Replacement: 8 단계, 이미지 2/2
    • Disconnect the 5 ribbon cables connected to the motherboard.
    • Remove the motherboard.
  9. LG Lucid 4G Headphone Jack Replacement: 9 단계, 이미지 1/2 LG Lucid 4G Headphone Jack Replacement: 9 단계, 이미지 2/2
    • Lift the additional ribbon in the top right quadrant.
    • Once that ribbon is lifted, the audio jack can easily be removed.
결론
Will Bonner
회원 가입일: 02/07/17
101 평판
안내서 1개 작성함
Ohio State, Team 1-1, Wilder Spring 2017 Ohio State, Team 1-1, Wilder Spring 2017 회원
OSU-WILDER-S17S1G1
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 6
전체 시간: 208
