주요 콘텐츠로 건너뛰기
LG Lucid 4G SIM Card Replacement
필요한 것
  1. LG Lucid 4G SIM Card Replacement, Battery: 1 단계, 이미지 1/3 LG Lucid 4G SIM Card Replacement, Battery: 1 단계, 이미지 2/3 LG Lucid 4G SIM Card Replacement, Battery: 1 단계, 이미지 3/3
    • Turn off the phone by pressing the power button, then press "Power Off", then press "OK" when notified that your phone will shut down.
  2. LG Lucid 4G SIM Card Replacement: 2 단계, 이미지 1/2 LG Lucid 4G SIM Card Replacement: 2 단계, 이미지 2/2
    • Flip the phone so that its back plate is facing upward.
    • Use your fingernail or prying tool to lift the back plate of the phone open by using the notch at the bottom.
  3. LG Lucid 4G SIM Card Replacement: 3 단계, 이미지 1/2 LG Lucid 4G SIM Card Replacement: 3 단계, 이미지 2/2
    • Using the notch located near the bottom center, remove the battery with a prying tool or your fingernail.
  4. LG Lucid 4G SIM Card Replacement, SIM Card: 4 단계, 이미지 1/1
    • After you have cleaned the battery area, locate the SIM card slot.
  5. LG Lucid 4G SIM Card Replacement: 5 단계, 이미지 1/1
    • Using your finger, carefully remove the SIM card from its slot by moving it toward the battery area.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Margaret Huck
회원 가입일: 02/07/17
219 평판
안내서 2개 작성하였습니다
Ohio State, Team 1-1, Wilder Spring 2017 Ohio State, Team 1-1, Wilder Spring 2017 회원
OSU-WILDER-S17S1G1
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 327
