소개
If phone will not turn on or has system errors and the troubleshooting did not help then replace the broken motherboard with a new one.
필요한 것
Use a plastic opening tool to remove the battery, lifting from the bottom right corner.
Use a plastic opening tool to lift the speaker off by prying under the silver square as shown.
Pry slightly underneath the tab attached to the camera until it pops off.
Pry off the circled tabs using a plastic opening tool to release the motherboard.
다른 7명이 해당 안내서를 완성하였습니다.
