주요 콘텐츠로 건너뛰기
LG Motion 4G MS770 Motherboard Replacement
필요한 것
  1. LG Motion 4G MS770 Motherboard Replacement, Remove the phone's back cover.: 1 단계, 이미지 1/1
    • Use a plastic opening tool to remove the back cover.
  2. LG Motion 4G MS770 Motherboard Replacement, Remove the battery.: 2 단계, 이미지 1/1
    • Use a plastic opening tool to remove the battery, lifting from the bottom right corner.
  3. LG Motion 4G MS770 Motherboard Replacement, Remove screws.: 3 단계, 이미지 1/1
    • Use a Phillips #00 Screwdriver to remove all eight 4mm screws.
  4. LG Motion 4G MS770 Motherboard Replacement: 4 단계, 이미지 1/2 LG Motion 4G MS770 Motherboard Replacement: 4 단계, 이미지 2/2
    • Use a plastic opening tool to remove the back trim by working around all of the edges.
  5. LG Motion 4G MS770 Motherboard Replacement: 5 단계, 이미지 1/2 LG Motion 4G MS770 Motherboard Replacement: 5 단계, 이미지 2/2
    • Remove the volume buttons from the side.
  6. LG Motion 4G MS770 Motherboard Replacement, Speaker: 6 단계, 이미지 1/2 LG Motion 4G MS770 Motherboard Replacement, Speaker: 6 단계, 이미지 2/2
    • Use a plastic opening tool to lift the speaker off by prying under the silver square as shown.
    • Note: There is a small tab underneath the speaker that will be lifted off when the speaker is removed.
  7. LG Motion 4G MS770 Motherboard Replacement, Rear Facing Camera: 7 단계, 이미지 1/1
    • Pry slightly underneath the tab attached to the camera until it pops off.
  8. LG Motion 4G MS770 Motherboard Replacement: 8 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Use tweezers to remove the camera, you will need to use some force as it is glued on.
  9. LG Motion 4G MS770 Motherboard Replacement, Motherboard: 9 단계, 이미지 1/1
    • Pry off the circled tabs using a plastic opening tool to release the motherboard.
  10. LG Motion 4G MS770 Motherboard Replacement: 10 단계, 이미지 1/1
    • Lift the motherboard off of the phone. It should come right out.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Zarna Patel
회원 가입일: 10/08/14
320 평판
안내서 2개 작성하였습니다
USF Tampa, Team 14-1, Leahy Fall 2014 USF Tampa, Team 14-1, Leahy Fall 2014 회원
USFT-LEAHY-F14S14G1
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 13
전체 시간: 1,302
