주요 콘텐츠로 건너뛰기
LG Motion 4G MS770 Speaker Replacement
필요한 것
  1. LG Motion 4G MS770 Speaker Replacement, Remove the phone's back cover.: 1 단계, 이미지 1/1
    • Use a plastic opening tool to remove the back cover.
  2. LG Motion 4G MS770 Speaker Replacement, Remove the battery.: 2 단계, 이미지 1/1
    • Use a plastic opening tool to remove the battery, lifting from the bottom right corner.
  3. LG Motion 4G MS770 Speaker Replacement, Remove screws.: 3 단계, 이미지 1/1
    • Use a Phillips #00 Screwdriver to remove all eight 4mm screws.
  4. LG Motion 4G MS770 Speaker Replacement: 4 단계, 이미지 1/2 LG Motion 4G MS770 Speaker Replacement: 4 단계, 이미지 2/2
    • Use a plastic opening tool to remove the back trim by working around all of the edges.
  5. LG Motion 4G MS770 Speaker Replacement: 5 단계, 이미지 1/2 LG Motion 4G MS770 Speaker Replacement: 5 단계, 이미지 2/2
    • Remove the volume buttons from the side.
  6. LG Motion 4G MS770 Speaker Replacement, Speaker: 6 단계, 이미지 1/2 LG Motion 4G MS770 Speaker Replacement, Speaker: 6 단계, 이미지 2/2
    • Use a plastic opening tool to lift the speaker off by prying under the silver square as shown.
    • Note: There is a small tab underneath the speaker that will be lifted off when the speaker is removed.
결론
Daniela Allbright
회원 가입일: 10/08/14
642 평판
안내서 3개 작성하였습니다
USF Tampa, Team 14-1, Leahy Fall 2014 USF Tampa, Team 14-1, Leahy Fall 2014 회원
USFT-LEAHY-F14S14G1
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 241
