주요 콘텐츠로 건너뛰기
LG Muziq LX570 Front Case Replacement
필요한 것
  1. LG Muziq LX570 Front Case Replacement, Front Case: 1 단계, 이미지 1/2 LG Muziq LX570 Front Case Replacement, Front Case: 1 단계, 이미지 2/2
    • Use a spudger to remove the two screw covers below display.
    • Use a screw driver to remove the four Phillips #00 (3.3mm) screws at corners of the display.
  2. LG Muziq LX570 Front Case Replacement: 2 단계, 이미지 1/3 LG Muziq LX570 Front Case Replacement: 2 단계, 이미지 2/3 LG Muziq LX570 Front Case Replacement: 2 단계, 이미지 3/3
    • Caution: Wires and ribbon connect the front case to the main body. Exhibit care when separating front case from the main body as to not break the connections.
    • Note: Side buttons may fall out when removing the front case. Do not misplace them.
    • Note: Each side button will only fit in the side that it came from.
    • Insert a spudger between the black and grey casings and gently spread them apart.
    • Work around the device gradually, opening the gap further.
  3. LG Muziq LX570 Front Case Replacement: 3 단계, 이미지 1/3 LG Muziq LX570 Front Case Replacement: 3 단계, 이미지 2/3 LG Muziq LX570 Front Case Replacement: 3 단계, 이미지 3/3
    • Caution: The wires and ribbon connector can break easily. Exhibit care when removing them.
    • Use the spudger and lift upward to disconnect the ribbon from the main part of the phone.
    • Carefully remove any parts stuck to the front case such as speakers.
결론
Raymond Ching
회원 가입일: 01/19/12
1 평판
안내서 1개 작성함
Cal Poly, Team 3-29, Amido Winter 2012 Cal Poly, Team 3-29, Amido Winter 2012 회원
CPSU-AMIDO-W12S3G29
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 571
