주요 콘텐츠로 건너뛰기
LG Muziq LX570 Motherboard Replacement
필요한 것
  1. LG Muziq LX570 Motherboard Replacement, Battery: 1 단계, 이미지 1/2 LG Muziq LX570 Motherboard Replacement, Battery: 1 단계, 이미지 2/2
    • Slide the battery cover release towards top of phone.
    • Place one finger at each side of the battery cover.
    • Lift and remove the battery cover.
  2. LG Muziq LX570 Motherboard Replacement: 2 단계, 이미지 1/2 LG Muziq LX570 Motherboard Replacement: 2 단계, 이미지 2/2
    • Place a finger at the top corner of the battery and lift out of the phone.
  3. LG Muziq LX570 Motherboard Replacement, Rear Case: 3 단계, 이미지 1/2 LG Muziq LX570 Motherboard Replacement, Rear Case: 3 단계, 이미지 2/2
    • Use the spudger to lift up the two screw covers at the top of the phone.
    • Remove all four Phillips#00 (3.3mm) screws with screwdriver.
  4. LG Muziq LX570 Motherboard Replacement: 4 단계, 이미지 1/3 LG Muziq LX570 Motherboard Replacement: 4 단계, 이미지 2/3 LG Muziq LX570 Motherboard Replacement: 4 단계, 이미지 3/3
    • Use the spudger to lift up the rear case from the phone.
    • Note: Rear case is connected on all sides and will have to be detached on all sides before removal.
    • Remove the rear case from the device.
  5. LG Muziq LX570 Motherboard Replacement, Motherboard: 5 단계, 이미지 1/3 LG Muziq LX570 Motherboard Replacement, Motherboard: 5 단계, 이미지 2/3 LG Muziq LX570 Motherboard Replacement, Motherboard: 5 단계, 이미지 3/3
    • Use the spudger to lift the motherboard from the phone.
결론
Braden Burk
회원 가입일: 01/22/12
1 평판
안내서 5개 작성하였습니다
Cal Poly, Team 3-29, Amido Winter 2012 Cal Poly, Team 3-29, Amido Winter 2012 회원
CPSU-AMIDO-W12S3G29
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 755
