주요 콘텐츠로 건너뛰기
LG Neon GT 365 Speaker Replacement
필요한 것
  1. LG Neon GT 365 Speaker Replacement, Speaker: 1 단계, 이미지 1/2 LG Neon GT 365 Speaker Replacement, Speaker: 1 단계, 이미지 2/2
    • With one hand, push the rectangular button located on the back top-side of the phone.
    • With your other hand, remove the rear cover.
  2. LG Neon GT 365 Speaker Replacement: 2 단계, 이미지 1/1
    • Remove 5 screws, 1 from each corner of the phone and 1 from the center-right of the phone.
  3. LG Neon GT 365 Speaker Replacement: 3 단계, 이미지 1/2 LG Neon GT 365 Speaker Replacement: 3 단계, 이미지 2/2
    • Now pull off the rear casing, using an opening tool. **Buttons for volume and pictures may fall out**
  4. LG Neon GT 365 Speaker Replacement: 4 단계, 이미지 1/1
    • Once you have removed the rear casing flip it over to see a small circular metal piece with 2 gold springs sticking out of the bottom. That is the speaker.
    • Opposite the 2 small gold springs there will be a small black tab attached to the speaker sitting in a groove. Using tweezers or a small tipped screwdriver lift up on the tab to pop the speaker out.
  5. LG Neon GT 365 Speaker Replacement: 5 단계, 이미지 1/1
    • Replace the broken speaker with a new one (make sure to line up the tab with the groove). Push firmly into place. Follow reverse instructions to put the rear casing and back cover on.
결론
kristie
회원 가입일: 10/23/13
538 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 2-1, Gulbrandsen Fall 2013 UMass Dartmouth, Team 2-1, Gulbrandsen Fall 2013 회원
UMASSD-GULBRANDSEN-F13S2G1
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 224
