소개
Make sure your device is turned off before beginning this process.
Pry the back cover off of the phone with your fingernail. There is a notch located at the bottom of the phone for improved leverage.
The battery is the large black rectangle towards the bottom half of the phone.
There is a semi-circular notch at the bottom edge of the battery. Press against and up on the battery to pop it out.
다른 2명이 해당 안내서를 완성하였습니다.
