주요 콘텐츠로 건너뛰기
LG Optimus 3D Headphone Jack Replacement
필요한 것
  1. LG Optimus 3D Headphone Jack Replacement, Back Cover Removal: 1 단계, 이미지 1/2 LG Optimus 3D Headphone Jack Replacement, Back Cover Removal: 1 단계, 이미지 2/2
    • Pry the back cover off of the phone with your fingernail. There is a notch located at the bottom of the phone for improved leverage.
  2. LG Optimus 3D Headphone Jack Replacement, Battery Removal: 2 단계, 이미지 1/3 LG Optimus 3D Headphone Jack Replacement, Battery Removal: 2 단계, 이미지 2/3 LG Optimus 3D Headphone Jack Replacement, Battery Removal: 2 단계, 이미지 3/3
    • The battery is the large black rectangle towards the bottom half of the phone.
    • There is a semi-circular notch at the bottom edge of the battery. Press against and up on the battery to pop it out.
  3. LG Optimus 3D Headphone Jack Replacement, Screw Removal: 3 단계, 이미지 1/2 LG Optimus 3D Headphone Jack Replacement, Screw Removal: 3 단계, 이미지 2/2
    • Remove 9 screws from the phone. The locations of these screws are circled in the picture.
    • 5.5mm length PH00 screws
    • 4mm length PH00 screws
  4. LG Optimus 3D Headphone Jack Replacement, Bottom Cover Removal: 4 단계, 이미지 1/2 LG Optimus 3D Headphone Jack Replacement, Bottom Cover Removal: 4 단계, 이미지 2/2
    • Gently pull down on the bottom cover to remove it.
  5. LG Optimus 3D Headphone Jack Replacement, Mid-Cover Bezel Removal: 5 단계, 이미지 1/3 LG Optimus 3D Headphone Jack Replacement, Mid-Cover Bezel Removal: 5 단계, 이미지 2/3 LG Optimus 3D Headphone Jack Replacement, Mid-Cover Bezel Removal: 5 단계, 이미지 3/3
    • Using a plastic opening tool, gently pry around the perimeter of the device.
    • The ribbons behind the buttons and ports are very delicate. Make sure you do not run your plastic opening tool too deep into the bezel, as you could damage them.
    • The button covers rest under the Mid-Cover Bezel. Remove them and set aside.
  6. LG Optimus 3D Headphone Jack Replacement, Ribbon Cable Disconnection: 6 단계, 이미지 1/2 LG Optimus 3D Headphone Jack Replacement, Ribbon Cable Disconnection: 6 단계, 이미지 2/2
    • Using a spudger or plastic opening tool, gently disconnect the ribbon cable attached to the black SIM card board.
  7. LG Optimus 3D Headphone Jack Replacement, Adhesive Loosening: 7 단계, 이미지 1/1
    • Use a hair-dryer on high, or a heat-gun on low to heat the device and loosen the adhesive which holds down the SD/SIM Card Board.
    • Evenly heat the device in short intervals for about one minute.
    • Do not heat the device for more than 30 seconds at a time to prevent over-heating.
  8. LG Optimus 3D Headphone Jack Replacement, SD/SIM Card Board Removal: 8 단계, 이미지 1/3 LG Optimus 3D Headphone Jack Replacement, SD/SIM Card Board Removal: 8 단계, 이미지 2/3 LG Optimus 3D Headphone Jack Replacement, SD/SIM Card Board Removal: 8 단계, 이미지 3/3
    • Gently pry the board up to release it from the now soft adhesive. Make sure you pry up the little tab connected to the camera unit as well.
    • If the board is too difficult to separate than more heating may be required.
  9. LG Optimus 3D Headphone Jack Replacement, Disconnect Ribbon Cables: 9 단계, 이미지 1/2 LG Optimus 3D Headphone Jack Replacement, Disconnect Ribbon Cables: 9 단계, 이미지 2/2
    • Using a spudger or plastic opening tool, gently lift the ribbon cables connected to the motherboard.
    • The button tabs, highlighted in orange, are held in with a light adhesive. Gently lift them out of the body of the phone with a spudger.
  10. LG Optimus 3D Headphone Jack Replacement, Disconnect Antenna: 10 단계, 이미지 1/2 LG Optimus 3D Headphone Jack Replacement, Disconnect Antenna: 10 단계, 이미지 2/2
    • Remove the antenna cable by disconnecting both ends.
    • One end connects to the motherboard and the other connects near bottom of the phone.
  11. LG Optimus 3D Headphone Jack Replacement, Remove Motherboard: 11 단계, 이미지 1/2 LG Optimus 3D Headphone Jack Replacement, Remove Motherboard: 11 단계, 이미지 2/2
    • Using a spudger gently lift the motherboard assembly out of the case.
    • Make sure the motherboard does not get snagged on the camera's ribbon cable.
  12. LG Optimus 3D Headphone Jack Replacement, Ribbon Cable Disconnection: 12 단계, 이미지 1/1
    • Using the plastic opening tool disconnect the ribbon cable connected to the headphone jack assembly.
  13. LG Optimus 3D Headphone Jack Replacement, Headphone Jack Removal: 13 단계, 이미지 1/2 LG Optimus 3D Headphone Jack Replacement, Headphone Jack Removal: 13 단계, 이미지 2/2
    • Separate the Headphone Jack from the body of the phone. It should pop off relatively easily.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Dale Pearson
회원 가입일: 09/22/14
784 평판
안내서 6개 작성하였습니다
USF Tampa, Team 10-6, Brown Fall 2014 USF Tampa, Team 10-6, Brown Fall 2014 회원
USFT-BROWN-F14S10G6
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 533
