주요 콘텐츠로 건너뛰기
LG Optimus F3 Charging port unit Replacement
필요한 것
  1. LG Optimus F3 Charging port unit  Replacement, Motherboard: 1 단계, 이미지 1/1
    • Turn the device so that the back faces up.
    • It is easiest to open the case near the charging port located at the bottom of the phone.
    • Remove the back case by pushing up on the back and pulling down on the face as illustrated in the image.
  2. LG Optimus F3 Charging port unit  Replacement: 2 단계, 이미지 1/1
    • With back case removed, the battery is visible. The battery is the large square object.
    • Remove the battery by flipping the bottom edge upward to separate the battery from the case.
  3. LG Optimus F3 Charging port unit  Replacement: 3 단계, 이미지 1/1
    • Remove 10 1.0 mm screws located on the back of the device.
    • Refer to the outlined locations in the image for the screws.
  4. LG Optimus F3 Charging port unit  Replacement: 4 단계, 이미지 1/1
    • Use the plastic opening tool to separate the inner case from the device.
    • Wedge the plastic opening tool between the case.
    • Wiggle the tool and use leverage to pry the case apart.
  5. LG Optimus F3 Charging port unit  Replacement: 5 단계, 이미지 1/1
    • The camera unit is located at the top left of the phone. The camera is a silver box with a black lens. The image pin points where the camera is on the motherboard.
    • Use the plastic opening tool to separate the camera from the motherboard.
    • Wedge the plastic tool between the camera and the motherboard to loosen the camera unit.
  6. LG Optimus F3 Charging port unit  Replacement: 6 단계, 이미지 1/1
    • Use a pair of tweezers to disconnect and remove the rear facing camera.
  7. LG Optimus F3 Charging port unit  Replacement: 7 단계, 이미지 1/1
    • Use the plastic opening tool to separate the sim card and the memory card connector from the motherboard.
    • Note that the sim card and the memory card connector are one unit.
    • Wedge the plastic tool to lift up the sim-memory unit from the motherboard.
  8. LG Optimus F3 Charging port unit  Replacement: 8 단계, 이미지 1/1
    • Use the plastic opening tool to remove the charging port unit.
    • Wedge the plastic opening tool between the charging port unit and the motherboard to separate the port.
  9. LG Optimus F3 Charging port unit  Replacement: 9 단계, 이미지 1/1
    • Use the plastic opening tool to remove the motherboard located directly above the battery encasement.
    • The motherboard is an L-shaped unit above and to the left of the battery encasement.
    • Wedge the plastic opening tool between the circuit board and the motherboard to separate the unit.
  10. LG Optimus F3 Charging port unit  Replacement, Charging port unit: 10 단계, 이미지 1/1
    • Remove one 1.0 mm screw.
  11. LG Optimus F3 Charging port unit  Replacement: 11 단계, 이미지 1/1
    • Use a plastic opening tool to remove front glass protector.
  12. LG Optimus F3 Charging port unit  Replacement: 12 단계, 이미지 1/1
    • Use the plastic opening tool to remove front glass cover carefully. Try not to break the connector.
  13. LG Optimus F3 Charging port unit  Replacement: 13 단계, 이미지 1/1
    • Remove the front facing camera.
  14. LG Optimus F3 Charging port unit  Replacement: 14 단계, 이미지 1/1
    • Use the plastic opening tool to carefully remove the home button board. It is attached with double-sided tape.
  15. LG Optimus F3 Charging port unit  Replacement: 15 단계, 이미지 1/1
  16. LG Optimus F3 Charging port unit  Replacement: 16 단계, 이미지 1/1
    • You are all set.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Jonathan Fang
회원 가입일: 10/28/15
356 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 1-5, Miles Fall 2015 UMass Dartmouth, Team 1-5, Miles Fall 2015 회원
UMASSD-MILES-F15S1G5
3 회원들
안내서 5개 작성하였습니다
0 Comments
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 548
