주요 콘텐츠로 건너뛰기
소개
In this step-by-step guide, you will be able to successfully replace your motherboard in your LG Optimus F3 device.
  1. Turn the device so that the back faces up.
    • Turn the device so that the back faces up.
    • It is easiest to open the case near the charging port located at the bottom of the phone.
    • Remove the back case by pushing up on the back and pulling down on the face as illustrated in the image.
  2. With back case removed, the battery is visible. The battery is the large square object.
    • With back case removed, the battery is visible. The battery is the large square object.
    • Remove the battery by flipping the bottom edge upward to separate the battery from the case.
  3. Remove 10  1.0 mm screws located on the back of the device.
    • Remove 10 1.0 mm screws located on the back of the device.
    • Refer to the outlined locations in the image for the screws.
  4. Use the plastic opening tool to separate the inner case from the device.
    • Use the plastic opening tool to separate the inner case from the device.
    • Wedge the plastic opening tool between the case.
    • Wiggle the tool and use leverage to pry the case apart.
  5. The camera unit is located at the top left of the phone. The camera is a silver box with a black lens.  The image pin points where the camera is on the motherboard.
    • The camera unit is located at the top left of the phone. The camera is a silver box with a black lens. The image pin points where the camera is on the motherboard.
    • Use the plastic opening tool to separate the camera from the motherboard.
    • Wedge the plastic tool between the camera and the motherboard to loosen the camera unit.
  6. Use a pair of tweezers to disconnect and remove the rear facing camera.
    • Use a pair of tweezers to disconnect and remove the rear facing camera.
  7. Use the plastic opening tool to separate the sim card and the memory card connector from the motherboard.
    • Use the plastic opening tool to separate the sim card and the memory card connector from the motherboard.
    • Note that the sim card and the memory card connector are one unit.
    • Wedge the plastic tool to lift up the sim-memory unit from the motherboard.
  8. Use the plastic opening tool to remove the charging port unit.
    • Use the plastic opening tool to remove the charging port unit.
    • Wedge the plastic opening tool between the charging port unit and the motherboard to separate the port.
  9. Use the plastic opening tool to remove the motherboard located directly above the battery encasement.
    • Use the plastic opening tool to remove the motherboard located directly above the battery encasement.
    • The motherboard is an L-shaped unit above and to the left of the battery encasement.
    • Wedge the plastic opening tool between the circuit board and the motherboard to separate the unit.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Battsooj Bayarsaikhan
회원 가입일: 2015년 10월 28일
101 평판
안내서 1개 작성함
UMass Dartmouth, Team 1-5, Miles Fall 2015 UMass Dartmouth, Team 1-5, Miles Fall 2015 회원
UMASSD-MILES-F15S1G5
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 525
