소개
This guide will show how to replace a faulty or broken charging port on a LG Optimus F60. This process is involves soldering and can take 25-35 minutes to complete.
필요한 것
Hold the phone in your hand and position the small plastic opening tool or your finger under the lip of the phone by the USB port.
Pry or lift up on the indent with the opening tool.
Remove the back panel.
Remove the charging port with the soldering iron.
To desolder, refer to this guide: How To Solder and Desolder Connections
Remove and replace the charging port.
다른 3명이 해당 안내서를 완성하였습니다.
