주요 콘텐츠로 건너뛰기
LG Optimus F60 Front Camera Replacement
필요한 것
  1. LG Optimus F60 Front Camera Replacement, Battery: 1 단계, 이미지 1/3 LG Optimus F60 Front Camera Replacement, Battery: 1 단계, 이미지 2/3 LG Optimus F60 Front Camera Replacement, Battery: 1 단계, 이미지 3/3
    • Hold the phone in your hand and position the small plastic opening tool or your finger under the lip of the phone by the USB port.
    • Pry or lift up on the indent with the opening tool.
    • Remove the back panel.
  2. LG Optimus F60 Front Camera Replacement: 2 단계, 이미지 1/3 LG Optimus F60 Front Camera Replacement: 2 단계, 이미지 2/3 LG Optimus F60 Front Camera Replacement: 2 단계, 이미지 3/3
    • Place the small plastic opening tool or your finger at the indentation at the base of the battery.
    • Pry upwards or lift with your finger and remove battery.
  3. LG Optimus F60 Front Camera Replacement, Front Camera: 3 단계, 이미지 1/2 LG Optimus F60 Front Camera Replacement, Front Camera: 3 단계, 이미지 2/2
    • Use the phillips #000 Screwdriver to unscrew eight 4mm screws.
  4. LG Optimus F60 Front Camera Replacement: 4 단계, 이미지 1/2 LG Optimus F60 Front Camera Replacement: 4 단계, 이미지 2/2
    • Insert the plastic opening tool in the indentation marked by the red square.
    • Pry the plastic opening tool upwards to release the lower back panel.
    • Remove the lower back panel from the device.
  5. LG Optimus F60 Front Camera Replacement: 5 단계, 이미지 1/3 LG Optimus F60 Front Camera Replacement: 5 단계, 이미지 2/3 LG Optimus F60 Front Camera Replacement: 5 단계, 이미지 3/3
    • Continue moving plastic opening tool around device until back panel is loose enough to remove.
  6. LG Optimus F60 Front Camera Replacement: 6 단계, 이미지 1/3 LG Optimus F60 Front Camera Replacement: 6 단계, 이미지 2/3 LG Optimus F60 Front Camera Replacement: 6 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Locate the digitizer connection on the lower left hand side of the device.
    • Use the tweezers to lift up and gently remove the connector.
  7. LG Optimus F60 Front Camera Replacement: 7 단계, 이미지 1/3 LG Optimus F60 Front Camera Replacement: 7 단계, 이미지 2/3 LG Optimus F60 Front Camera Replacement: 7 단계, 이미지 3/3
    • Locate the front camera on the upper left hand side of the device. The camera is marked in red.
    • Use the tweezers to remove the front camera from the connector marked in orange.
    • Remove and replace front camera.
결론
Austin Johnson
회원 가입일: 04/09/18
171 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 9
전체 시간: 211
