소개
This guide explain step by step how to replace the battery of your LG Optimus G with a couple of tools.
부품
지정된 부품이 없습니다.
Remove the 2 screws holding the back cover using a T5 screwdriver.
Use a guitar pick or a plastic opening tool to free the clips on the top and each side of the back cover.
Remove the tape over the battery, the screws and the antenna connector cord.
다른 7명이 해당 안내서를 완성하였습니다.
댓글 5개
I’m not using a heat gun, it´s a hairdryer; on this case the hairdryer hardly exceeds the 60°C and that is enough to remove the battery. If you want to buy a heat gun you must be careful not to use more than 50 °
you can search it on Amazon and buy directly from LG.
Thank you so much for this wonderful article it helped me replace my battery. I bought my replacement battery from here:-
