주요 콘텐츠로 건너뛰기
LG Optimus G Battery Replacement
필요한 것
  1. LG Optimus G Battery Replacement, Remove the simcard: 1 단계, 이미지 1/2 LG Optimus G Battery Replacement, Remove the simcard: 1 단계, 이미지 2/2
    • SIM eject tool
  2. LG Optimus G Battery Replacement, Remove the back cover: 2 단계, 이미지 1/2 LG Optimus G Battery Replacement, Remove the back cover: 2 단계, 이미지 2/2
    • Remove the 2 screws holding the back cover using a T5 screwdriver.
    • Use a guitar pick or a plastic opening tool to free the clips on the top and each side of the back cover.
    • Use an opening pick to pry off the rear case.
  3. LG Optimus G Battery Replacement, Removing the battery: 4 단계, 이미지 1/2 LG Optimus G Battery Replacement, Removing the battery: 4 단계, 이미지 2/2
    • Remove the tape over the battery, the screws and the antenna connector cord.
    • Be careful removing the golden tape because it is below the antenna connector cord.
  4. LG Optimus G Battery Replacement: 5 단계, 이미지 1/2 LG Optimus G Battery Replacement: 5 단계, 이미지 2/2
    • Remove the the screws securing the battery cable connector.
    • Disconnect the battery cable.
  5. LG Optimus G Battery Replacement: 6 단계, 이미지 1/1
    • The battery is held down by some adhesive.
    • Carefully heat the battery to loosen the adhesive holding it to the case.
  6. LG Optimus G Battery Replacement: 7 단계, 이미지 1/2 LG Optimus G Battery Replacement: 7 단계, 이미지 2/2
    • Pry the battery up from the case.
    • Be very careful not to puncture the battery when prying. Use blunt plastic tools.
  7. LG Optimus G Battery Replacement: 8 단계, 이미지 1/3 LG Optimus G Battery Replacement: 8 단계, 이미지 2/3 LG Optimus G Battery Replacement: 8 단계, 이미지 3/3
    • The battery is removed.
    • Replace the battery with a new one.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Eneider Colina
회원 가입일: 09/20/13
2,362 평판
안내서 9개 작성하였습니다
Comunidad para traductores de español Comunidad para traductores de español 회원
Community
24 회원들
안내서 246개 작성하였습니다
댓글 5개
“Heat gun”is too vague. So is IR thermometer. What temperature to soften adhesive? How would I know if I was buying the right things?
Deep - 답글
I’m not using a heat gun, it´s a hairdryer; on this case the hairdryer hardly exceeds the 60°C and that is enough to remove the battery. If you want to buy a heat gun you must be careful not to use more than 50 °
Eneider Colina - 답글
Where do you suggest ordering a replacement battery from?
snack le - 답글
you can search it on Amazon and buy directly from LG.
Eneider Colina -
Thank you so much for this wonderful article it helped me replace my battery. I bought my replacement battery from here:-
https://www.phonepartworld.com/LG/LG-Opt...
ricksanchez - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 14
전체 시간: 5,127
