주요 콘텐츠로 건너뛰기
LG Optimus G Pro Battery Replacement
필요한 것
  1. LG Optimus G Pro Battery Replacement, Remove Back Cover.: 1 단계, 이미지 1/1
    • Make sure before you begin working on your device, that the device is not charging.
    • Once you have access to the phone, there is a small indent on the bottom left side. Use your fingernail or a plastic opening tool to pry from here and pull off the back casing.
  2. LG Optimus G Pro Battery Replacement, Remove the Battery.: 2 단계, 이미지 1/1
    • Once you have properly removed the outer casing, the back should look as so.
    • To remove the battery, pull up from the red mark using your finger. The battery should come up at an angle, and easily be able to be removed.
    • Once the battery is removed you may safely proceed to the next step.
결론
다른 10명이 해당 안내서를 완성하였습니다.
Wesley Pate
회원 가입일: 09/25/14
1,641 평판
안내서 7개 작성하였습니다
USF Tampa, Team 15-5, Remmell Fall 2014 USF Tampa, Team 15-5, Remmell Fall 2014 회원
USFT-REMMELL-F14S15G5
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 3,202
