소개
Is the back camera of the device not working properly? Time to replace it with a new and better one! Follow this easy and quick guide!
부품
부품은 필요하지 않습니다.
  1. Insert a plastic opening tool between the seams of the device and pry the back cover away from the phone. Remove the battery and SIM card.
    • Insert a plastic opening tool between the seams of the device and pry the back cover away from the phone.
    • Remove the battery and SIM card.
  2. Lift the three connectors using the plastic spudger.
    • Lift the three connectors using the plastic spudger.
  3. US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  4. Starting from the right, remove the attached black mount using the plastic spudger. Starting from the right, remove the attached black mount using the plastic spudger.
    • Starting from the right, remove the attached black mount using the plastic spudger.
  5. Apply some pressure on the back of the mount to detach the camera. Replace the camera as needed.
    • Apply some pressure on the back of the mount to detach the camera.
    • Replace the camera as needed.
결론
Veronica D'Agosta
회원 가입일: 2017년 01월 26일
101 평판
안내서 1개 작성함
IUPUI, Team 2-2, Baechle Spring 2017 IUPUI, Team 2-2, Baechle Spring 2017 회원
IUPUI-BAECHLE-S17S2G2
4 회원들
안내서 3개 작성하였습니다
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 161
