주요 콘텐츠로 건너뛰기
LG Optimus L7 P705 SIM Card Slot Replacement
필요한 것
  1. LG Optimus L7 P705 SIM Card Slot Replacement, Home Button: 1 단계, 이미지 1/2 LG Optimus L7 P705 SIM Card Slot Replacement, Home Button: 1 단계, 이미지 2/2
    • Insert a plastic opening tool between the seams of the device and pry the back cover away from the phone.
    • Remove the battery and SIM card.
  2. LG Optimus L7 P705 SIM Card Slot Replacement: 2 단계, 이미지 1/1
    • Remove the twelve screws using the Phillips 000 screwdriver.
  3. LG Optimus L7 P705 SIM Card Slot Replacement: 3 단계, 이미지 1/1
    • Remove bottom plate where the charger port is located.
  4. LG Optimus L7 P705 SIM Card Slot Replacement: 4 단계, 이미지 1/2 LG Optimus L7 P705 SIM Card Slot Replacement: 4 단계, 이미지 2/2
    • Insert a plastic opening tool between the seams of the device and apply some pressure to lift off the cover.
  5. LG Optimus L7 P705 SIM Card Slot Replacement: 5 단계, 이미지 1/1
    • Flip over to the face of the device.
    • Lift off the glass screen (display).
  6. LG Optimus L7 P705 SIM Card Slot Replacement: 6 단계, 이미지 1/1
    • Remove the home screen button. Replace as needed.
  7. LG Optimus L7 P705 SIM Card Slot Replacement, SIM Card Slot: 7 단계, 이미지 1/2 LG Optimus L7 P705 SIM Card Slot Replacement, SIM Card Slot: 7 단계, 이미지 2/2
    • Flip over to the back of the device
    • Using the plastic spudger, lift off the three board-to-board connectors on the left-hand side of the device.
  8. LG Optimus L7 P705 SIM Card Slot Replacement: 8 단계, 이미지 1/1
    • Using a plastic spudger, lift off the wire connector at the right bottom of the board.
  9. LG Optimus L7 P705 SIM Card Slot Replacement: 9 단계, 이미지 1/2 LG Optimus L7 P705 SIM Card Slot Replacement: 9 단계, 이미지 2/2
    • Detach the mount including both the SIM card and the motherboard from the device.
결론
Yanxiang Ding
회원 가입일: 01/25/17
101 평판
안내서 1개 작성함
IUPUI, Team 2-2, Baechle Spring 2017 IUPUI, Team 2-2, Baechle Spring 2017 회원
IUPUI-BAECHLE-S17S2G2
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 6
전체 시간: 626
