소개
This guide will guide you step-by-step on how to replace the screen on the LG Optimus L9 smartphone. This requires the knowledge of removing the motherboard. Make sure to work in a static-free environment to avoid damaging the components. Make sure to be extra careful with removing the connections as this may lead to permanently damaging them.
필요한 것
Start by placing the device face down and remove the back cove.
Remove the battery from the phone by lifting it using your finger or the prying tool
Using a spudger or small prying tool, pry off the latches that connects the digitizer to the chassis carefully.
다른 한 분이 해당 안내서를 완성하였습니다.
