주요 콘텐츠로 건너뛰기
LG Optimus L9 P769 Micro-USB Port Replacement
필요한 것
  1. LG Optimus L9 P769 Micro-USB Port Replacement, Micro-USB Port: 1 단계, 이미지 1/1
    • Power off the device and gently lift the battery cover off to access the battery
  2. LG Optimus L9 P769 Micro-USB Port Replacement: 2 단계, 이미지 1/1
    • Lift and remove the battery from the notch in the edge of the battery compartment
  3. LG Optimus L9 P769 Micro-USB Port Replacement: 3 단계, 이미지 1/2 LG Optimus L9 P769 Micro-USB Port Replacement: 3 단계, 이미지 2/2
    • Remove all 10 of the 4.5mm screws that hold the back frame to the case of the phone using a PH000 screwdriver.
  4. LG Optimus L9 P769 Micro-USB Port Replacement: 4 단계, 이미지 1/2 LG Optimus L9 P769 Micro-USB Port Replacement: 4 단계, 이미지 2/2
    • Using a small prying tool, carefully remove the back frame by prying on the sides of the device.
    • Do be careful when prying back frame and removing it as too much force may result in damaging the frame.
  5. LG Optimus L9 P769 Micro-USB Port Replacement: 5 단계, 이미지 1/3 LG Optimus L9 P769 Micro-USB Port Replacement: 5 단계, 이미지 2/3 LG Optimus L9 P769 Micro-USB Port Replacement: 5 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Remove both connections of the antenna by pulling up with tweezers
  6. LG Optimus L9 P769 Micro-USB Port Replacement: 6 단계, 이미지 1/3 LG Optimus L9 P769 Micro-USB Port Replacement: 6 단계, 이미지 2/3 LG Optimus L9 P769 Micro-USB Port Replacement: 6 단계, 이미지 3/3
    • Remove Micro-USB Cache by unscrewing both 2.9mm screws with the PH000 headtype
  7. LG Optimus L9 P769 Micro-USB Port Replacement: 7 단계, 이미지 1/1
    • Detach module from motherboard using a prying tool
  8. LG Optimus L9 P769 Micro-USB Port Replacement: 8 단계, 이미지 1/2 LG Optimus L9 P769 Micro-USB Port Replacement: 8 단계, 이미지 2/2
    • Remove 1.8mm screw to free Micro-USB module for removal using the PH000 headtype
  9. LG Optimus L9 P769 Micro-USB Port Replacement: 9 단계, 이미지 1/2 LG Optimus L9 P769 Micro-USB Port Replacement: 9 단계, 이미지 2/2
    • Use a small prying tool to detach the Micro-USB circuitry from the case of the phone
  10. LG Optimus L9 P769 Micro-USB Port Replacement: 10 단계, 이미지 1/1
    • Comparison showing the Micro-USB module against the empty phone casing
결론
Kayden G
회원 가입일: 03/01/17
272 평판
안내서 2개 작성하였습니다
IUPUI, Team S2-G1, Harley Spring 2017 IUPUI, Team S2-G1, Harley Spring 2017 회원
IUPUI-HARLEY-S17S2G1
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 8
전체 시간: 326
