주요 콘텐츠로 건너뛰기
LG Optimus L9 P769 Motherboard Replacement
필요한 것
  1. LG Optimus L9 P769 Motherboard Replacement, Motherboard: 1 단계, 이미지 1/3 LG Optimus L9 P769 Motherboard Replacement, Motherboard: 1 단계, 이미지 2/3 LG Optimus L9 P769 Motherboard Replacement, Motherboard: 1 단계, 이미지 3/3
    • Start by placing the device face down and remove the back cove.
    • Remove the battery from the phone by lifting it using your finger or the prying tool
  2. LG Optimus L9 P769 Motherboard Replacement: 2 단계, 이미지 1/3 LG Optimus L9 P769 Motherboard Replacement: 2 단계, 이미지 2/3 LG Optimus L9 P769 Motherboard Replacement: 2 단계, 이미지 3/3
    • Remove all 10 of the 4.5mm Phillips screws that holds the back frame to the case of the phone
    • Using a small plastic prying tool, carefully remove the back frame by prying on the sides of the device.
    • Do be careful when prying back frame and removing it as too much force may result in damaging the frame.
  3. LG Optimus L9 P769 Motherboard Replacement: 3 단계, 이미지 1/3 LG Optimus L9 P769 Motherboard Replacement: 3 단계, 이미지 2/3 LG Optimus L9 P769 Motherboard Replacement: 3 단계, 이미지 3/3
    • Using tweezers, pinch the sides of the antenna node and pull straight up.
    • Using a small prying tool, carefully remove the ribbon cables attached to the motherboard.
  4. LG Optimus L9 P769 Motherboard Replacement: 4 단계, 이미지 1/2 LG Optimus L9 P769 Motherboard Replacement: 4 단계, 이미지 2/2
    • Using a spudger or small prying tool, lift up the motherboard from the chassis of the device.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Ammar Rizal
회원 가입일: 03/01/17
225 평판
안내서 2개 작성하였습니다
IUPUI, Team S2-G1, Harley Spring 2017 IUPUI, Team S2-G1, Harley Spring 2017 회원
IUPUI-HARLEY-S17S2G1
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 2
전체 시간: 492
