주요 콘텐츠로 건너뛰기
LG Optimus L9 P769 Rear Facing Camera Replacement
필요한 것
  1. LG Optimus L9 P769 Rear Facing Camera Replacement, Removing the Back Panel: 1 단계, 이미지 1/2 LG Optimus L9 P769 Rear Facing Camera Replacement, Removing the Back Panel: 1 단계, 이미지 2/2
    • Pry the back panel from the frame of the phone to reveal the motherboard.
  2. LG Optimus L9 P769 Rear Facing Camera Replacement, Unpluging the Motherboard: 2 단계, 이미지 1/3 LG Optimus L9 P769 Rear Facing Camera Replacement, Unpluging the Motherboard: 2 단계, 이미지 2/3 LG Optimus L9 P769 Rear Facing Camera Replacement, Unpluging the Motherboard: 2 단계, 이미지 3/3
    • Detach the connectors on the motherboard.
  3. LG Optimus L9 P769 Rear Facing Camera Replacement, Unpluging the Motherboard Cont.: 3 단계, 이미지 1/3 LG Optimus L9 P769 Rear Facing Camera Replacement, Unpluging the Motherboard Cont.: 3 단계, 이미지 2/3 LG Optimus L9 P769 Rear Facing Camera Replacement, Unpluging the Motherboard Cont.: 3 단계, 이미지 3/3
    • Continue to lift the connectors off the motherboard.
  4. LG Optimus L9 P769 Rear Facing Camera Replacement, Lifting Motherboard from the Phone: 4 단계, 이미지 1/3 LG Optimus L9 P769 Rear Facing Camera Replacement, Lifting Motherboard from the Phone: 4 단계, 이미지 2/3 LG Optimus L9 P769 Rear Facing Camera Replacement, Lifting Motherboard from the Phone: 4 단계, 이미지 3/3
    • Lift the speaker cable off the motherboard.
    • Lift the motherboard up. It will Still be connected to the frame.
  5. LG Optimus L9 P769 Rear Facing Camera Replacement, Pry and remove the camera: 5 단계, 이미지 1/3 LG Optimus L9 P769 Rear Facing Camera Replacement, Pry and remove the camera: 5 단계, 이미지 2/3 LG Optimus L9 P769 Rear Facing Camera Replacement, Pry and remove the camera: 5 단계, 이미지 3/3
    • Pry under the camera to lift it off the frame.
    • There is some adhesive that will keep it attached to the frame, pulling the camera off will not damage the phone.
    • The camera should now be entirely separated from the phone.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Paul
회원 가입일: 10/07/14
145 평판
안내서 4개 작성하였습니다
USF Tampa, Team 8-1, Leahy Fall 2014 USF Tampa, Team 8-1, Leahy Fall 2014 회원
USFT-LEAHY-F14S8G1
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 9
전체 시간: 972
