주요 콘텐츠로 건너뛰기
LG Optimus L9 P769 Speaker Replacement
필요한 것
  1. LG Optimus L9 P769 Speaker Replacement, Position: 1 단계, 이미지 1/1
    • Position the phone face-down.
  2. LG Optimus L9 P769 Speaker Replacement, Rear Case Removal: 2 단계, 이미지 1/2 LG Optimus L9 P769 Speaker Replacement, Rear Case Removal: 2 단계, 이미지 2/2
    • Hold the phone in your hand and position your fingernail or a opening tool under the lip at the bottom of the case.
    • Pry rear case upwards until you hear a click.
    • Remove rear case.
  3. LG Optimus L9 P769 Speaker Replacement, Battery Removal: 3 단계, 이미지 1/3 LG Optimus L9 P769 Speaker Replacement, Battery Removal: 3 단계, 이미지 2/3 LG Optimus L9 P769 Speaker Replacement, Battery Removal: 3 단계, 이미지 3/3
    • Place the phone face-down.
    • Place your thumb or tool in the indentation and remove the battery.
  4. LG Optimus L9 P769 Speaker Replacement, Unscrew The Bottom: 4 단계, 이미지 1/2 LG Optimus L9 P769 Speaker Replacement, Unscrew The Bottom: 4 단계, 이미지 2/2
    • Remove the three screws from the bottom of the phone to unscrew the speaker.
  5. LG Optimus L9 P769 Speaker Replacement, Remove Speaker: 5 단계, 이미지 1/3 LG Optimus L9 P769 Speaker Replacement, Remove Speaker: 5 단계, 이미지 2/3 LG Optimus L9 P769 Speaker Replacement, Remove Speaker: 5 단계, 이미지 3/3
    • Place a prying tool between the speaker and the phone.
    • Gently lift the speaker out of the phone.
결론
Mekia Edwards
회원 가입일: 10/14/14
10 평판
안내서 1개 작성함
USF Tampa, Team 8-1, Leahy Fall 2014 USF Tampa, Team 8-1, Leahy Fall 2014 회원
USFT-LEAHY-F14S8G1
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 998
