주요 콘텐츠로 건너뛰기
LG Optimus T Camera and Camera Mount Replacement
필요한 것
  1. LG Optimus T Camera and Camera Mount Replacement, Camera: 1 단계, 이미지 1/2 LG Optimus T Camera and Camera Mount Replacement, Camera: 1 단계, 이미지 2/2
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down your device before you begin.
    • Use a plastic opening tool to remove the phone's back cover. At the top of the phone there are indentations to insert the spudger and pop the case off
  2. LG Optimus T Camera and Camera Mount Replacement: 2 단계, 이미지 1/1
    • Remove the battery by pulling up on the battery using the indentation to the left of the camera lens
  3. LG Optimus T Camera and Camera Mount Replacement: 3 단계, 이미지 1/1
    • Use a J0 screwdriver to remove the 6 highlighted screws
  4. LG Optimus T Camera and Camera Mount Replacement: 4 단계, 이미지 1/2 LG Optimus T Camera and Camera Mount Replacement: 4 단계, 이미지 2/2
    • Remove interior case using indentations on the top and bottom to insert the spudger to pop off the interior case
    • You might have difficulty popping the interior case off. You may use the metal spudger here with caution if the plastic one fails
  5. LG Optimus T Camera and Camera Mount Replacement: 5 단계, 이미지 1/1
    • Unhook the connector tab
  6. LG Optimus T Camera and Camera Mount Replacement: 6 단계, 이미지 1/1
    • Remove SD card mount by inserting the plastic opening tool on the right side of the device to pop mount off
  7. LG Optimus T Camera and Camera Mount Replacement: 7 단계, 이미지 1/2 LG Optimus T Camera and Camera Mount Replacement: 7 단계, 이미지 2/2
    • Remove metal panel by inserting plastic opening tool into the four retaining points and remove panel
  8. LG Optimus T Camera and Camera Mount Replacement: 8 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • disconnect camera connector from motherboard by spudger
    • Once disconnected, remove camera using tweezers
결론
stacey
회원 가입일: 02/07/17
219 평판
안내서 2개 작성하였습니다
Ohio State, Team 1-3, Wilder Spring 2017 Ohio State, Team 1-3, Wilder Spring 2017 회원
OSU-WILDER-S17S1G3
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 9
전체 시간: 121
