주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
This guide will walk you through how to replace the screen on your LG Optimus V phone.
부품
지정된 부품이 없습니다.
  1. Turn the LG Optimus V over so that the back cover is facing upward.
    • Turn the LG Optimus V over so that the back cover is facing upward.
  2. Locate the opening right above the camera.
    • Locate the opening right above the camera.
    • Use a spudger to detach the back cover.
  3. Gently remove the battery with your spudger. Gently remove the battery with your spudger. Gently remove the battery with your spudger.
    • Gently remove the battery with your spudger.
  4. Remove the six screws on the silver casing. Use the plastic opening tool to remove the silver casing.
    • Remove the six screws on the silver casing.
    • Use the plastic opening tool to remove the silver casing.
  5. Use a plastic opening tool to remove each area holding the parts together. Use a plastic opening tool to remove each area holding the parts together. Use a plastic opening tool to remove each area holding the parts together.
    • Use a plastic opening tool to remove each area holding the parts together.
  6. Use a plastic opening tool to remove the small black and yellow piece that reads Y3114C. Use a plastic opening tool to pry off the camera.
    • Use a plastic opening tool to remove the small black and yellow piece that reads Y3114C.
    • Use a plastic opening tool to pry off the camera.
  7. Once you have removed the antenna, unscrew the two screws located on the sides of the charging port.
    • Once you have removed the antenna, unscrew the two screws located on the sides of the charging port.
  8. Using your plastic opening tool, lift up the connectors on either side of the motherboard. Using your plastic opening tool, lift up the connectors on either side of the motherboard.
    • Using your plastic opening tool, lift up the connectors on either side of the motherboard.
  9. Remove the motherboard and set it aside.
    • Remove the motherboard and set it aside.
  10. Using a plastic opening tool, detach the screen from the plastic casing of the phone.
    • Using a plastic opening tool, detach the screen from the plastic casing of the phone.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Joseph Pasquantonio
회원 가입일: 2013년 10월 29일
683 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 1-2, Shastany Fall 2013 UMass Dartmouth, Team 1-2, Shastany Fall 2013 회원
UMASSD-SHASTANY-F13S1G2
3 회원들
안내서 5개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 4
전체 시간: 2,427
