주요 콘텐츠로 건너뛰기
LG Optimus V Speaker Replacement
필요한 것
  1. LG Optimus V Speaker Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the LG Optimus V over, so that the back cover is facing upward.
  2. LG Optimus V Speaker Replacement: 2 단계, 이미지 1/1
    • Locate the opening above the camera.
    • Use a spudger to detach the back cover.
  3. LG Optimus V Speaker Replacement: 3 단계, 이미지 1/3 LG Optimus V Speaker Replacement: 3 단계, 이미지 2/3 LG Optimus V Speaker Replacement: 3 단계, 이미지 3/3
    • Gently remove the battery with your spudger.
  4. LG Optimus V Speaker Replacement, Camera: 4 단계, 이미지 1/2 LG Optimus V Speaker Replacement, Camera: 4 단계, 이미지 2/2
    • Remove the six screws on the silver casing.
    • Use the plastic opening tool to remove the silver casing.
  5. LG Optimus V Speaker Replacement: 5 단계, 이미지 1/3 LG Optimus V Speaker Replacement: 5 단계, 이미지 2/3 LG Optimus V Speaker Replacement: 5 단계, 이미지 3/3
    • Use a plastic opening tool to remove each area holding the parts together.
  6. LG Optimus V Speaker Replacement: 6 단계, 이미지 1/2 LG Optimus V Speaker Replacement: 6 단계, 이미지 2/2
    • Use a plastic opening tool to remove the small black and yellow piece that reads Y3114C.
    • Use a plastic opening tool to pry off the camera.
  7. LG Optimus V Speaker Replacement, Speaker: 7 단계, 이미지 1/1
    • This is the area that holds the speaker.
  8. LG Optimus V Speaker Replacement: 8 단계, 이미지 1/2 LG Optimus V Speaker Replacement: 8 단계, 이미지 2/2
    • To fix the speaker, use a soldering iron to heat up the two areas where the wires connect to the motherboard. Then, remove the old speaker and replace it with a new one by soldering it back onto the same areas.
    • Once you’re done, your speaker should be working properly again.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Joseph Pasquantonio
회원 가입일: 10/29/13
683 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 1-2, Shastany Fall 2013 UMass Dartmouth, Team 1-2, Shastany Fall 2013 회원
UMASSD-SHASTANY-F13S1G2
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 796
