소개
If you need to install a new headphone jack on your LG Phoenix 2, use this guide to disassemble and replace the damaged part. For this guide you will need a plastic opening tool and a Phillips #000 screwdriver. These steps will be straightforward and easy to follow, but the pieces should be handled with care, so as to not damage or misplace any needed components.
필요한 것
Insert a fingernail into the notch on the bottom right corner of the phone.
Pop off the back cover off of your device.
다른 한 분이 해당 안내서를 완성하였습니다.
