소개
If you need to install a new outside trim on your LG Phoenix 2, use this guide to disassemble and replace the damaged outer trim. For this guide you will need a plastic opening tool and a Phillips #000 screwdriver head. These steps will be straightforward and easy to follow, but the pieces should be handled with care, so as to not damage or misplace any needed components.
필요한 것
Insert a fingernail in the notch on the bottom right corner of the phone.
Pop off the back cover off of your device.
다른 2명이 해당 안내서를 완성하였습니다.
