주요 콘텐츠로 건너뛰기
LG Realm Front Facing Camera Replacement
필요한 것
  1. LG Realm Front Facing Camera Replacement, Battery: 1 단계, 이미지 1/2 LG Realm Front Facing Camera Replacement, Battery: 1 단계, 이미지 2/2
    • To remove the back, insert thumbnail into MicroUSB port, and pull up to loosen back.
    • Use nail to loosen case on all four sides. Once loose, remove back case.
  2. LG Realm Front Facing Camera Replacement: 2 단계, 이미지 1/1
    • Insert thumbnail into tab below battery.
    • Pull away from phone and remove.
  3. LG Realm Front Facing Camera Replacement, Plastic Midframe: 3 단계, 이미지 1/2 LG Realm Front Facing Camera Replacement, Plastic Midframe: 3 단계, 이미지 2/2
    • Once the back cover and battery are removed, use the Phillips #J000 screwdriver to remove all 11 screws located around the plastic midframe.
  4. LG Realm Front Facing Camera Replacement: 4 단계, 이미지 1/1
    • Using the plastic opening tool, carefully pry and separate the plastic midframe from the rest of the phone.
  5. LG Realm Front Facing Camera Replacement, Front Facing Camera: 5 단계, 이미지 1/1
    • Locate the front facing camera in the top left hand corner of the motherboard. Using the plastic opening tool, separate the ribbon cable from the phone.
  6. LG Realm Front Facing Camera Replacement: 6 단계, 이미지 1/1
    • After removing this ribbon cable, you will be able to easily remove the front facing camera with your fingers.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Ryan St Martin
회원 가입일: 03/05/16
770 평판
안내서 4개 작성하였습니다
Marist, Team 1-5, Laflen Spring 2016 Marist, Team 1-5, Laflen Spring 2016 회원
MARS-LAFLEN-S16S1G5
2 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 13
전체 시간: 407
